Introducción
If your car charger is no longer plugging in correctly, or if you have noticed that the metal sides of it are no longer in their correct shape, this guide can help you replace those metal side pieces, called: negative contacts. Negative Contacts in car phone chargers may get bent or stuck inside the device, making it difficult to plug back in.
If there is a possibility this is because your car charger got wet, you will need to proceed with caution, and wear gloves once you reach the circuit board.
Qué necesitas
Remove the two 5 mm Phillips screws with a Phillips #1 screwdriver.
Remove the cover.
Replace your negative contacts, or bend them back into their correct shape. Resembling a half oval shape as shown.
To begin reassembling the car charger first, lay the circuit board side into the bottom half of the car charger's case.
Make sure to align the light with its correct spot. It should be in the small, half-circle indent.
To reassemble your device, go back to step 2 then step 1, and follow them in reverse order.
Una persona más ha completado esta guía.
