Saltar al contenido principal
Introducción
1°/ Remove the 4 screws on the bottom (take care because to one, the blue screw, of them is shorter than others).
Partes
No se especificaron partes.
  1. 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
    • 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
    • Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
  4. Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
    • Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
Conclusión
8 personas más completaron esta guía.
Greg
Miembro Desde 10/12/12
349 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 10
Todo El Tiempo: 2,449
