Introducción
First this guide will outline how to check that everything in the battery module is correct. This will include the long list of warnings that you need to be aware of when replacing the battery. Second, the details of replacing the battery module will be outlined.
Before starting know that the Battery module is rated 12 V,3.5 Ah. The battery backup time is approx. 0.5 hour/battery and up to six backup Battery modules can be connected to the module. If looking for more detailed instructions while reading through this guide refer to pages 19-22 of the Siemens User Guide. Also page 4-18 and 5-2 on the service manual.
Service Manual- 4-18
Qué necesitas
1. Locate a small hexagonal wrench or screwdriver.
Place the tool in the small hole on the right hand side.
2. Simultaneously push the release button.
3. Remove the tool, while still pressing the release button.
4. Continue to keep the button pressed until the battery pops out.
5. Pull out the battery module.
