Saltar al contenido principal
Siemens A56 Front Plate Replacement
Qué necesitas
  1. Siemens A56 Front Plate Replacement, Battery: paso 1, imagen 1 de 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Front Plate Replacement: paso 2, imagen 1 de 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Front Plate Replacement, Front Plate: paso 3, imagen 1 de 3 Siemens A56 Front Plate Replacement, Front Plate: paso 3, imagen 2 de 3 Siemens A56 Front Plate Replacement, Front Plate: paso 3, imagen 3 de 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
Conclusión
Lauren Young
Miembro Desde 03/26/14
322 Reputación
3 Guías creadas
Equipo
Clemson, Team 6-6, Benson Spring 2014 Miembro de Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 171
