Saltar al contenido principal
Shure SM58 XLR Microphone Connector Installation Replacement
Qué necesitas
  1. Shure SM58 XLR Microphone Connector Installation Replacement, XLR Microphone Connector Installation: paso 1, imagen 1 de 1
    • Holding the microphone connector in one hand and the microphone base in the other, line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  2. Shure SM58 XLR Microphone Connector Installation Replacement: paso 2, imagen 1 de 1
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  3. Shure SM58 XLR Microphone Connector Installation Replacement: paso 3, imagen 1 de 1
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Conclusión
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4 personas más completaron esta guía.
Ronald Lam
Miembro Desde 09/27/12
329 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-53, Forte Fall 2012 Miembro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
Miembros de 5
30 Guías creadas
7 comentarios
Hi. I have followed the steps to #3. “Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight. “ However, the connector does not stay in place. It is still loose where the connector moves inside the microphone. I cannot get it to sit tight .
Joe Lee - Contestar
Hi. I followed up to step #3. However, the connector does not stay tight. It keeps on moving inside with a little push.
Joe Lee - Contestar
Hi. I followed up to step #3. But, the connect is still loose… Moves inside the microphone.
Joe Lee - Contestar
Are the threads on your screw stripped?
Daniel Berger - Contestar
Hi I have lost the screw in the side of the mic. Can you tell me the size of a replacement or where I can get one. Thank you
Chris Hall - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 38
Todo El Tiempo: 10,847
