Saltar al contenido principal
Shower Handle O-ring Replacement
Qué necesitas
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: paso 1, imagen 1 de 1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
  2. Shower Handle O-ring  Replacement: paso 2, imagen 1 de 1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
  3. Shower Handle O-ring  Replacement: paso 3, imagen 1 de 1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
  4. Shower Handle O-ring  Replacement: paso 4, imagen 1 de 1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
  5. Shower Handle O-ring  Replacement: paso 5, imagen 1 de 2 Shower Handle O-ring  Replacement: paso 5, imagen 2 de 2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
Linea de Meta
3 personas más completaron esta guía.
Equipo
2 comentarios
I have to change my shower handle, but the plumber asking me to change the shower valve also. But I can’t see any reason to replace the shower valve, is it really necessary to change it when changing shower handle.
Thanks.
Rose Geiger - Contestar
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 53
Ultimos 30 días: 239
Todo El Tiempo: 20,904
