Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Shower Handle O-ring Replacement
Qué necesitas
  1. Shower Handle O-ring  Replacement, Shower Handle O-ring: paso 1, imagen 1 de 1
    • Be sure your water main is turned off, preventing water flow to your shower.
    • Using your flat head screwdriver, remove the screw from the middle of the handle.
    Pregunta a FixBot
  2. Shower Handle O-ring  Replacement: paso 2, imagen 1 de 1
    • Use your groove joint pliers to loosen and remove the escutcheon plate.
    Pregunta a FixBot
  3. Shower Handle O-ring  Replacement: paso 3, imagen 1 de 1
    • Using your groove joint pliers, loosen and remove the cartridge stem.
    Pregunta a FixBot
  4. Shower Handle O-ring  Replacement: paso 4, imagen 1 de 1
    • Slowly unscrew and remove the stem completely.
    • There may be some water leakage due to built up pressure.
    Pregunta a FixBot
  5. Shower Handle O-ring  Replacement: paso 5, imagen 1 de 2 Shower Handle O-ring  Replacement: paso 5, imagen 2 de 2
    • Using your flat head screwdriver, remove the screw from the end of the stem cartridge.
    • Once the screw is removed, replace the damaged O-ring with the new replacement O-ring.
    • When installing a new O-ring, be sure the O-ring has a tight seal to prevent further leaking.
    • Once reassembly is complete and all parts are snug, turn the water main back on to allow water to flow to the shower again.
    Pregunta a FixBot
Linea de Meta
3 personas más completaron esta guía.
Equipo
4Guía Comentarios
This fixed the dripping shower head but now my shower handles are tight and difficult to turn and the water pressure is affected after replacing the o-rings. What could the issue be?
Cin - Contestar Compartir
Try putting petroleum jelly all over the outside of the stem/cartridge (including the threading/grooves) before screwing it all back together. That will keep your handles turning smoothly, and easily.
It's the plumbing equivalent to WD40.
Jess - Contestar Compartir
As for the change in water pressure, I'm not sure what that would be. Did you use the same size O-ring?
I have the same handles and stems, but leaking not from the rubber. Leaking occuring when tuning on the handle. Do you know where to find the parts?
Phil Yue - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 43
Ultimos 30 días: 198
Todo El Tiempo: 26,018
