Saltar al contenido principal
Shop-Vac MC150A Power Switch Replacement
Qué necesitas
  1. Shop-Vac MC150A Power Switch Replacement, Unlatch the power unit assembly: paso 1, imagen 1 de 1
    • Before you begin, make sure to switch off the device and unplug it from the outlet.
    • Unlatch the two side clips securing the power unit assembly to the tank.
    • Remove the power unit assembly from the tank assembly.
  2. Shop-Vac MC150A Power Switch Replacement, Remove the top cover: paso 2, imagen 1 de 2 Shop-Vac MC150A Power Switch Replacement, Remove the top cover: paso 2, imagen 2 de 2
    • Use a 3.5 mm hex key to remove the three screws securing the top cover.
    • Remove the top cover.
  3. Shop-Vac MC150A Power Switch Replacement: paso 3, imagen 1 de 1
    • Use a 3.5 mm hex key to remove the four screws securing the power unit assembly.
  4. Shop-Vac MC150A Power Switch Replacement: paso 4, imagen 1 de 1
    • Separate the power unit assembly from the cover.
  5. Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: paso 5, imagen 1 de 3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: paso 5, imagen 2 de 3 Shop-Vac MC150A Power Switch Replacement, Disconnect the switch: paso 5, imagen 3 de 3
    • Pull out and disconnect the four spade connectors from the switch module.
    • During reassembly, use the last image as a reference for how to connect the wires.
  6. Shop-Vac MC150A Power Switch Replacement: paso 6, imagen 1 de 1
    • Use a spudger to pry up and remove the red switch from the housing.
Conclusión
6 personas más completaron esta guía.
Ngunlian
Miembro Desde 02/08/16
732 Reputación
5 Guías creadas
Equipo
IUPUI, Team 1-2, Baechle Spring 2016 Miembro de IUPUI, Team 1-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G2
5 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 34
Ultimos 30 días: 119
Todo El Tiempo: 16,067
