Saltar al contenido principal
Sharper Image SVC430 Tripod Nut Replacement
Qué necesitas
  1. Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: paso 1, imagen 1 de 2 Sharper Image SVC430 Tripod Nut Replacement, Sharper Image SVC430 Disassembly: paso 1, imagen 2 de 2
    • Power off your device before you begin.
    • Use your thumb to push down on the lever that says "open" while simultaneously pushing up the latch with your other thumb.
  2. Sharper Image SVC430 Tripod Nut Replacement: paso 2, imagen 1 de 2 Sharper Image SVC430 Tripod Nut Replacement: paso 2, imagen 2 de 2
    • Once the latch is free, simply pull the front of the waterproof case off and slide the camera out.
  3. Sharper Image SVC430 Tripod Nut Replacement: paso 3, imagen 1 de 3 Sharper Image SVC430 Tripod Nut Replacement: paso 3, imagen 2 de 3 Sharper Image SVC430 Tripod Nut Replacement: paso 3, imagen 3 de 3
    • Locate the bottom of the device.
    • Now, using the metal screwdriver, unscrew the screw on the bottom of the device.
  4. Sharper Image SVC430 Tripod Nut Replacement: paso 4, imagen 1 de 2 Sharper Image SVC430 Tripod Nut Replacement: paso 4, imagen 2 de 2
    • This panel should come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the plastic panel from the top of the camera.
    • Locate the two screws on the top of the device.
  5. Sharper Image SVC430 Tripod Nut Replacement: paso 5, imagen 1 de 1
    • Use the JIS J0 screwdriver to unscrew the two screws on the top of the device.
  6. Sharper Image SVC430 Tripod Nut Replacement: paso 6, imagen 1 de 3 Sharper Image SVC430 Tripod Nut Replacement: paso 6, imagen 2 de 3 Sharper Image SVC430 Tripod Nut Replacement: paso 6, imagen 3 de 3
    • Use the plastic opening tool to pry off the back panel.
    • The back panel will come off easily.
  7. Sharper Image SVC430 Tripod Nut Replacement: paso 7, imagen 1 de 1
    • Use the metal screwdriver to unscrew the screw from the back of the device.
  8. Sharper Image SVC430 Tripod Nut Replacement: paso 8, imagen 1 de 1
    • Use the plastic opening tool to pry off the front panel of the device.
  9. Sharper Image SVC430 Tripod Nut Replacement: paso 9, imagen 1 de 1
    • Using the screwdriver, unscrew the screw located underneath the front panel.
  10. Sharper Image SVC430 Tripod Nut Replacement: paso 10, imagen 1 de 1
    • Be gentle with the device since there are wires attached to the front plate and two halves.
    • Gently pull both sides of the device to expose the interior of the device.
  11. Sharper Image SVC430 Tripod Nut Replacement, Tripod Nut: paso 11, imagen 1 de 1
    • Locate the two screws that attach the tripod nut to the device.
  12. Sharper Image SVC430 Tripod Nut Replacement: paso 12, imagen 1 de 2 Sharper Image SVC430 Tripod Nut Replacement: paso 12, imagen 2 de 2
    • Unscrew the two screws located on the back of the half that the tripod nut is located.
    • Once the screws are removed, the tripod nut can easily be removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 228
