Saltar al contenido principal
Sharper Image SVC430 On/Off Button Replacement
Qué necesitas
  1. Sharper Image SVC430 On/Off Button Replacement, On/Off Button: paso 1, imagen 1 de 1
    • Position the device on/off button side up.
  2. Sharper Image SVC430 On/Off Button Replacement: paso 2, imagen 1 de 1
    • The back panel will come off easily, do not apply too much pressure.
    • Use the plastic opening tool to pry open the back panel of the device.
  3. Sharper Image SVC430 On/Off Button Replacement: paso 3, imagen 1 de 1
    • To replace the on/off button, you must replace the entire back panel. The on/off button cannot be removed from the panel.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 279
