Saltar al contenido principal
Sharper Image SVC430 Mount Rubber Washer Replacement
  1. Sharper Image SVC430 Mount Rubber Washer Replacement, Mount Rubber Washer: paso 1, imagen 1 de 1
    • Locate the knobs on either side of the mount screw.
  2. Sharper Image SVC430 Mount Rubber Washer Replacement: paso 2, imagen 1 de 1
    • Twist the knob so it comes off from the mount.
  3. Sharper Image SVC430 Mount Rubber Washer Replacement: paso 3, imagen 1 de 1
    • Once you have twisted apart the knobs, the rubber washer should easily fall out of the base.
    • This component is identical on the other mount, so this guide applies for both mounts.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 96
