Introducción
Speakers rely on precisely placed components to convert electronic signals into sound waves. Touching the speaker by pushing or pulling can cause the speaker components to deform. As a result, the speaker will no longer produce an accurate sound. Replacing the speaker is the best repair for speaker damage.
Unplug the speaker before doing any work on it.
  • Unplug the speaker before doing any work on it.
  • Use a #0 Phillips screwdriver to remove the eight 13mm Phillips head screws from the back panel.
Agregar Comentario
Remove the back panel.
  • Remove the back panel.
Agregar Comentario
  • Remove the snap cable that connects the speaker to the circuit board.
Agregar Comentario
  • Use a tap hammer and a punch to release the 4 posts that hold the front panel in place.
Agregar Comentario
  • Use a plastic opening tool or spudger to pry off the front panel.
Agregar Comentario
  • Use a#4 Phillips screwdriver to remove the four 9.5mm screws that secure the subwoofer to the woofer box.
Agregar Comentario
  • Remove the defective speaker.
Agregar Comentario
Conclusión
Linda Freund
Miembro Desde 06/08/17
205 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 92
