Saltar al contenido principal
Sharp-EL-531xg Battery Replacement
Qué necesitas
  1. Sharp-EL-531xg Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Press the 2nd F button and then the OFF button to power down the calculator.
  2. Sharp-EL-531xg Battery Replacement: paso 2, imagen 1 de 2 Sharp-EL-531xg Battery Replacement: paso 2, imagen 2 de 2
    • Flip the calculator over so the back is facing upwards.
    • Remove the single screw from the battery panel using a Phillips #0 screwdriver.
  3. Sharp-EL-531xg Battery Replacement: paso 3, imagen 1 de 1
    • Remove the battery cover using two fingers.
  4. Sharp-EL-531xg Battery Replacement: paso 4, imagen 1 de 3 Sharp-EL-531xg Battery Replacement: paso 4, imagen 2 de 3 Sharp-EL-531xg Battery Replacement: paso 4, imagen 3 de 3
    • Place a spudger in the slot next to the battery and pry upwards to remove the battery.
    • Avoid using a sharp tool to remove the battery.
  5. Sharp-EL-531xg Battery Replacement: paso 5, imagen 1 de 1
    • Place the new battery into the slot with the positive (+) side facing upwards
    • Don't press the battery too hard.
  6. Sharp-EL-531xg Battery Replacement: paso 6, imagen 1 de 1
    • Put the battery cover back on.
    • Tighten the battery cover screw with a Phillips #0 screwdriver.
  7. Sharp-EL-531xg Battery Replacement: paso 7, imagen 1 de 2 Sharp-EL-531xg Battery Replacement: paso 7, imagen 2 de 2
    • Press the On button to turn on the calculator.
    • Flip the calculator over so the bottom is facing upwards.
    • Press the reset button with the pointed end of a spudger to restart the calculator.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 29
Todo El Tiempo: 274
