Introducción
Use this guide to replace the snooze button on the Sharp SPC026 alarm clock. The alarm clock should be fairly simple to handle and take apart. If you follow the directions, it should be an easy repair.
Qué necesitas
Locate and remove the screws found underneath the alarm clock.
Separate the bottom and top of the alarm clock by pulling them apart.
Disconnect the battery.
Una persona más ha completado esta guía.
