Introducción
You'll be replacing the keyboard component of the Sharp PC - MM20!
Qué necesitas
Once the cover is loose, you should be able to wiggle it somewhat freely. However, there are a few connections holding it together.
Next, we're going to use tweezers to delicately remove the flat cable connecting the key board to the laptop.
Also, remove the flat cable from the track pad to the laptop.
Una persona más ha completado esta guía.
