Introducción
I am not responsible for anything in this article.
  1. Remove - Back,microSD,battery,sim
    • Remove - Back,microSD,battery,sim
    • Remove black rubber screw covers on back of display.
    • Remove 000 phillips screws (4) from top of display.
  2. Remove 3 small silver screws from battery area.
    • Remove 3 small silver screws from battery area.
    • Remove 2 Torx t-7's by MicroSD slot.
    • After screws are removed you can detach screen.
    • Remove 4 additional 000 phillips screws from display.
    • Using some heat,spudger,frce pry away the broken display from the frame.
    • Use extreme caution the actual display is very fragile.
    • Remove connector for digitizer
    • replace connector with new digitizer and rebuild.
    • Reconnect to main motherboard.
    • reassemble.
    • Enjoy the new display
Conclusión
Una persona más ha completado esta guía.
jckoniecki
Miembro Desde 08/11/10
51 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 3,241
