Saltar al contenido principal
Sharp EL-510RN Calculator Battery Replacement
Qué necesitas
  1. Sharp EL-510RN Calculator Battery Replacement, Battery: paso 1, imagen 1 de 2 Sharp EL-510RN Calculator Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Find a clean workspace free of clutter.
    • Cover the calculator with the gray screen it came with. This will prevent any buttons from being pressed when it's flipped over.
  2. Sharp EL-510RN Calculator Battery Replacement: paso 2, imagen 1 de 3 Sharp EL-510RN Calculator Battery Replacement: paso 2, imagen 2 de 3 Sharp EL-510RN Calculator Battery Replacement: paso 2, imagen 3 de 3
    • Flip the calculator over so the backside is facing up.
    • Use a Phillips #0 screwdriver to remove the screw securing the battery cover.
    • Use a spudger to pry open the battery cover.
  3. Sharp EL-510RN Calculator Battery Replacement: paso 3, imagen 1 de 3 Sharp EL-510RN Calculator Battery Replacement: paso 3, imagen 2 de 3 Sharp EL-510RN Calculator Battery Replacement: paso 3, imagen 3 de 3
    • Use a spudger to pry the battery out of the back of the calculator.
    • Always use an ESD safe tool when working with batteries or delicate components such as the motherboard.
  4. Sharp EL-510RN Calculator Battery Replacement: paso 4, imagen 1 de 3 Sharp EL-510RN Calculator Battery Replacement: paso 4, imagen 2 de 3 Sharp EL-510RN Calculator Battery Replacement: paso 4, imagen 3 de 3
    • Insert the new battery into the socket.
    • Put the panel back on and screw it into place.
  5. Sharp EL-510RN Calculator Battery Replacement: paso 5, imagen 1 de 1
    • Congratulations you've now successfully completed a battery replacement on the Sharp EL-510RN!
Conclusión
Harish Kugathasalingam
Miembro Desde 10/21/22
121 Reputación
1 Guía escrita
Equipo
York University, Team 4-5, Allen Fall 2022 Miembro de York University, Team 4-5, Allen Fall 2022
YORK-ALLEN-F22S4G5
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 13
Ultimos 30 días: 33
Todo El Tiempo: 209
