Saltar al contenido principal
Sharp Aquos LC13B2UA Buttons Replacement
Qué necesitas
  1. Sharp Aquos LC13B2UA Buttons Replacement, Stand: paso 1, imagen 1 de 2 Sharp Aquos LC13B2UA Buttons Replacement, Stand: paso 1, imagen 2 de 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Buttons Replacement: paso 2, imagen 1 de 2 Sharp Aquos LC13B2UA Buttons Replacement: paso 2, imagen 2 de 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Buttons Replacement, Back Case: paso 3, imagen 1 de 3 Sharp Aquos LC13B2UA Buttons Replacement, Back Case: paso 3, imagen 2 de 3 Sharp Aquos LC13B2UA Buttons Replacement, Back Case: paso 3, imagen 3 de 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Buttons Replacement: paso 4, imagen 1 de 2 Sharp Aquos LC13B2UA Buttons Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Buttons Replacement: paso 5, imagen 1 de 1
    • Using your hands, gently lift and remove the back case of the television.
  6. Sharp Aquos LC13B2UA Buttons Replacement, Motherboard: paso 6, imagen 1 de 3 Sharp Aquos LC13B2UA Buttons Replacement, Motherboard: paso 6, imagen 2 de 3 Sharp Aquos LC13B2UA Buttons Replacement, Motherboard: paso 6, imagen 3 de 3
    • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
    • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  7. Sharp Aquos LC13B2UA Buttons Replacement: paso 7, imagen 1 de 2 Sharp Aquos LC13B2UA Buttons Replacement: paso 7, imagen 2 de 2
    • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
    • Remove the green/gray to orange/gray connector from the center of the circuit board.
  8. Sharp Aquos LC13B2UA Buttons Replacement: paso 8, imagen 1 de 2 Sharp Aquos LC13B2UA Buttons Replacement: paso 8, imagen 2 de 2
    • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  9. Sharp Aquos LC13B2UA Buttons Replacement: paso 9, imagen 1 de 1
    • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  10. Sharp Aquos LC13B2UA Buttons Replacement, Power Button: paso 10, imagen 1 de 3 Sharp Aquos LC13B2UA Buttons Replacement, Power Button: paso 10, imagen 2 de 3 Sharp Aquos LC13B2UA Buttons Replacement, Power Button: paso 10, imagen 3 de 3
    • Remove the two 6mm Phillips screws.
    • Pull the board toward you, giving you access to the power button.
  11. Sharp Aquos LC13B2UA Buttons Replacement, Top Buttons: paso 11, imagen 1 de 2 Sharp Aquos LC13B2UA Buttons Replacement, Top Buttons: paso 11, imagen 2 de 2
    • Unscrew the two 4mm Phillips screws.
    • Lift the buttons off the front case.
Conclusión
Robert Hobson
Miembro Desde 01/20/11
1,290 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 1-11, Amido Winter 2011 Miembro de Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,947
