Saltar al contenido principal
Sharp Aquos Crystal USB Port Replacement
Qué necesitas
  1. Sharp Aquos Crystal USB Port Replacement, Back Panel: paso 1, imagen 1 de 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: paso 1, imagen 2 de 3 Sharp Aquos Crystal USB Port Replacement, Back Panel: paso 1, imagen 3 de 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal USB Port Replacement, USB Port: paso 2, imagen 1 de 2 Sharp Aquos Crystal USB Port Replacement, USB Port: paso 2, imagen 2 de 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal USB Port Replacement: paso 3, imagen 1 de 2 Sharp Aquos Crystal USB Port Replacement: paso 3, imagen 2 de 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal USB Port Replacement: paso 4, imagen 1 de 2 Sharp Aquos Crystal USB Port Replacement: paso 4, imagen 2 de 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal USB Port Replacement: paso 5, imagen 1 de 3 Sharp Aquos Crystal USB Port Replacement: paso 5, imagen 2 de 3 Sharp Aquos Crystal USB Port Replacement: paso 5, imagen 3 de 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal USB Port Replacement: paso 6, imagen 1 de 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
Conclusión
Una persona más ha completado esta guía.
Felicia Imbriano
Miembro Desde 03/08/16
1,169 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 2,142
