Saltar al contenido principal
Sharp Aquos Crystal Rear Camera Replacement
Qué necesitas
  1. Sharp Aquos Crystal Rear Camera Replacement, Back Panel: paso 1, imagen 1 de 3 Sharp Aquos Crystal Rear Camera Replacement, Back Panel: paso 1, imagen 2 de 3 Sharp Aquos Crystal Rear Camera Replacement, Back Panel: paso 1, imagen 3 de 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal Rear Camera Replacement, USB Port: paso 2, imagen 1 de 2 Sharp Aquos Crystal Rear Camera Replacement, USB Port: paso 2, imagen 2 de 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Rear Camera Replacement: paso 3, imagen 1 de 2 Sharp Aquos Crystal Rear Camera Replacement: paso 3, imagen 2 de 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Rear Camera Replacement: paso 4, imagen 1 de 2 Sharp Aquos Crystal Rear Camera Replacement: paso 4, imagen 2 de 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal Rear Camera Replacement: paso 5, imagen 1 de 3 Sharp Aquos Crystal Rear Camera Replacement: paso 5, imagen 2 de 3 Sharp Aquos Crystal Rear Camera Replacement: paso 5, imagen 3 de 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Rear Camera Replacement: paso 6, imagen 1 de 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
  7. Sharp Aquos Crystal Rear Camera Replacement, Motherboard: paso 7, imagen 1 de 1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Rear Camera Replacement: paso 8, imagen 1 de 1
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Rear Camera Replacement: paso 9, imagen 1 de 2 Sharp Aquos Crystal Rear Camera Replacement: paso 9, imagen 2 de 2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Rear Camera Replacement: paso 10, imagen 1 de 1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Rear Camera Replacement: paso 11, imagen 1 de 1
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Rear Camera Replacement, Rear Camera: paso 12, imagen 1 de 2 Sharp Aquos Crystal Rear Camera Replacement, Rear Camera: paso 12, imagen 2 de 2
    • Disconnect the camera from the board using a plastic opening tool.
    • Remove the camera from the back of the circuit board.
Conclusión
Felicia Imbriano
Miembro Desde 03/08/16
1,169 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 985
