Saltar al contenido principal
Sharp Aquos Crystal Battery Replacement
Qué necesitas
  1. Sharp Aquos Crystal Battery Replacement, Back Panel: paso 1, imagen 1 de 3 Sharp Aquos Crystal Battery Replacement, Back Panel: paso 1, imagen 2 de 3 Sharp Aquos Crystal Battery Replacement, Back Panel: paso 1, imagen 3 de 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
  2. Sharp Aquos Crystal Battery Replacement, USB Port: paso 2, imagen 1 de 2 Sharp Aquos Crystal Battery Replacement, USB Port: paso 2, imagen 2 de 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Battery Replacement: paso 3, imagen 1 de 2 Sharp Aquos Crystal Battery Replacement: paso 3, imagen 2 de 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Battery Replacement: paso 4, imagen 1 de 2 Sharp Aquos Crystal Battery Replacement: paso 4, imagen 2 de 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
  5. Sharp Aquos Crystal Battery Replacement: paso 5, imagen 1 de 3 Sharp Aquos Crystal Battery Replacement: paso 5, imagen 2 de 3 Sharp Aquos Crystal Battery Replacement: paso 5, imagen 3 de 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Battery Replacement: paso 6, imagen 1 de 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
  7. Sharp Aquos Crystal Battery Replacement, Motherboard: paso 7, imagen 1 de 1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Battery Replacement: paso 8, imagen 1 de 1
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Battery Replacement: paso 9, imagen 1 de 2 Sharp Aquos Crystal Battery Replacement: paso 9, imagen 2 de 2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Battery Replacement: paso 10, imagen 1 de 1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Battery Replacement: paso 11, imagen 1 de 1
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Battery Replacement, Battery: paso 12, imagen 1 de 1
    • Peel off the tape holding the battery down.
  13. Sharp Aquos Crystal Battery Replacement: paso 13, imagen 1 de 2 Sharp Aquos Crystal Battery Replacement: paso 13, imagen 2 de 2
    • Lift the battery out with your hands.
Conclusión
6 personas más completaron esta guía.
Felicia Imbriano
Miembro Desde 03/08/16
1,169 Reputación
8 Guías creadas
Equipo
3 comentarios
very helpful. I already replace my sharp 305sh battery
and then I find my power button is out of order.
so i just can keep it still on. use shake to lock screen and touch to unlock.
restart by unplug sim card.
but these day I made it out of power.so it turn off. however I use anyway to make it alive but I can’t.
luck me. I HARDLY PRESS camera left side near down the power button side and press on button .
It turns on.
the power board need to touch on some device on anther side.
!Mucho Gracias!
jeanpaolo lin - Contestar
hello, where can I buy this battery ? thanks, Ari
ari leon Kolbar - Contestar
battery connector located on motherbaoard has been broken when i was changing my aquos R2 battery.....kind guide me what to do now.....should we use jumper wires direct to the battery ??? if yes then guide me
Masood Ali - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 113
Todo El Tiempo: 14,345
