Saltar al contenido principal
Shark Vertex Pro IZ682H Pre-Motor Filter Replacement
Qué necesitas
  1. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Battery: paso 1, imagen 1 de 1
    • On the bottom of the device handle, you will find a button on the left side. Press and hold this button.
  2. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: paso 2, imagen 1 de 1
    • While holding the button, slide the battery out of the device.
    • If the battery needs replacing, you can find one on the Shark website.
  3. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Pre-Motor Filter: paso 3, imagen 1 de 2 Shark Vertex Pro IZ682H Pre-Motor Filter Replacement, Pre-Motor Filter: paso 3, imagen 2 de 2
    • On the body of the device you will find there is a large grey button on the side of the dust cup.
    • Pressing this button will release the dust cup from the body of the device.
    • Empty the dust cup if the device has already been in use.
  4. Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: paso 4, imagen 1 de 2 Shark Vertex Pro IZ682H Pre-Motor Filter Replacement: paso 4, imagen 2 de 2
    • Under the dust cup you will find that there is a white pre-motor filter. Remove this filter.
Conclusión
Tyree Brooks
Miembro Desde 10/26/22
486 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Miembro de UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 342
