Saltar al contenido principal
Shark Vertex Pro IZ682H Brush Roller Replacement
  1. Shark Vertex Pro IZ682H Brush Roller Replacement, Brush Roller: paso 1, imagen 1 de 1
    • Detach the power nozzle from the vacuum and turn it so the right side is facing you. Pull down the blue tab in the direction of the arrow.
    • The brush roller should now pop out.
    • Putting the brush roller in again does not require pulling the blue tab. It should pop in with no problem.
Conclusión
Tyree Brooks
Miembro Desde 10/26/22
495 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 3-2, Botvin Fall 2022 Miembro de UMass Dartmouth, Team 3-2, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G2
Miembros de 2
5 Guías creadas
1Guía Comentario
Hey there, where can I find the replacement rollers? I have been looking around and I do not see any that name the product exactly or in listed in compatible. Are they standard size or something like that?
John Melo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 51
Todo El Tiempo: 1,433
