Saltar al contenido principal
Shark Ultimate Professional Mode Display Replacement
Qué necesitas
  1. Shark Ultimate Professional Mode Display Replacement, Mode Display: paso 1, imagen 1 de 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: paso 1, imagen 2 de 3 Shark Ultimate Professional Mode Display Replacement, Mode Display: paso 1, imagen 3 de 3
    • Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure the iron is unplugged and cooled off.
  2. Shark Ultimate Professional Mode Display Replacement: paso 2, imagen 1 de 2 Shark Ultimate Professional Mode Display Replacement: paso 2, imagen 2 de 2
    • Use the Philips head #0 screwdriver to remove the two 11.77mm screws holding the white clamp to the iron.
    • Use the Philips head #0 screwdriver to remove the two 6.58mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
  3. Shark Ultimate Professional Mode Display Replacement: paso 3, imagen 1 de 3 Shark Ultimate Professional Mode Display Replacement: paso 3, imagen 2 de 3 Shark Ultimate Professional Mode Display Replacement: paso 3, imagen 3 de 3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside the power cord.
  4. Shark Ultimate Professional Mode Display Replacement: paso 4, imagen 1 de 3 Shark Ultimate Professional Mode Display Replacement: paso 4, imagen 2 de 3 Shark Ultimate Professional Mode Display Replacement: paso 4, imagen 3 de 3
    • Use the Philips head #0 screwdriver to remove remaining 6.58mm screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Wires order (from left to right): Brown, Blue, Black, Red
    • Unclip the black adapter piece on the bottom right.
  5. Shark Ultimate Professional Mode Display Replacement: paso 5, imagen 1 de 2 Shark Ultimate Professional Mode Display Replacement: paso 5, imagen 2 de 2
    • Use the Philips head #0 screwdriver to remove two 9.75mm screws (left and right) affixed to circuit board.
  6. Shark Ultimate Professional Mode Display Replacement: paso 6, imagen 1 de 2 Shark Ultimate Professional Mode Display Replacement: paso 6, imagen 2 de 2
    • Use the Philips head #0 screwdriver to remove the two 9.82mm screws (left and right) from the white border on top of the circuit board.
    • Pull the circuit board out from its affixed position.
  7. Shark Ultimate Professional Mode Display Replacement: paso 7, imagen 1 de 3 Shark Ultimate Professional Mode Display Replacement: paso 7, imagen 2 de 3 Shark Ultimate Professional Mode Display Replacement: paso 7, imagen 3 de 3
    • Lift the handle and wiggle the plastic trim and the orange-chrome bezel out from under the handle.
    • Remove and set aside the mode display.
Conclusión
Una persona más ha completado esta guía.
Drew Carff
Miembro Desde 10/23/17
868 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G4, Leahy Fall 2017 Miembro de USF Tampa, Team S1-G4, Leahy Fall 2017
USFT-LEAHY-F17S1G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 688
