Saltar al contenido principal
Shark Steam Pocket Mop Power Cable Replacement
Qué necesitas
  1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: paso 1, imagen 1 de 3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: paso 1, imagen 2 de 3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: paso 1, imagen 3 de 3
    • Begin by removing the 8 quarter inch phillips head screws found along the back panel
    • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
  2. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: paso 2, imagen 1 de 2 Shark Steam Pocket Mop Power Cable Replacement, Power Cable: paso 2, imagen 2 de 2
    • Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
    • Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
    • Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
Conclusión
Jacob Howe
Miembro Desde 10/10/17
549 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S13-G7, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 26
Todo El Tiempo: 1,705
