Saltar al contenido principal
Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement
Qué necesitas
  1. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: paso 1, imagen 1 de 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush: paso 1, imagen 2 de 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 2, imagen 1 de 1
    • Turn over the vacuum to reveal the roller brush.
  3. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 3, imagen 1 de 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 3, imagen 2 de 2
    • Pry the small wheels at the bottom of the base using the plastic opening tool.
  4. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 4, imagen 1 de 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 4, imagen 2 de 2
    • Using a coin, turn the big white knobs located above the roller brush counter-clockwise.
  5. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 5, imagen 1 de 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 5, imagen 2 de 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 5, imagen 3 de 3
    • Lift up the suction hose to reveal a screw.
    • Remove the 12.7 mm Phillips #02 screw.
  6. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 6, imagen 1 de 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 6, imagen 2 de 2
    • Remove eight 12.7mm screws located under the vacuum using a Phillips #02 screwdriver.
    • Remove two 12.7 mm screws located next to the wheels with a Phillips #02 screwdriver.
    • The two screws located next to the wheels are smaller in diameter.
  7. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 7, imagen 1 de 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 7, imagen 2 de 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 7, imagen 3 de 3
    • Turn the vacuum upright and pull the white upper section of the brush roller circuit housing.
    • Be careful when lifting the housing as there is a connector attached.
  8. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 8, imagen 1 de 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 8, imagen 2 de 2
    • Remove the connector attached to the circuit boards using a plastic opening tool.
  9. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 9, imagen 1 de 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 9, imagen 2 de 3 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 9, imagen 3 de 3
    • Remove the two 12.7 mm screws located at the top of the clear plastic brush roller housing using a Phillips #02 screwdriver.
    • Lift the clear plastic brush roller housing.
  10. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 10, imagen 1 de 2 Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 10, imagen 2 de 2
    • Wiggle the brush roller upwards from the left and right side slots.
  11. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement, Roller Brush Belt: paso 11, imagen 1 de 1
    • Remove the roller brush by sliding it out toward the left, off the belt.
  12. Shark Rotator Slim-Light Lift-Away Upright Roller Brush Belt Replacement: paso 12, imagen 1 de 1
    • Remove the belt from the motor gear by sliding the belt away from the gear and belt motor.
    • In the following picture the belt was already removed.
Conclusión
Daniel Ceja
Miembro Desde 01/24/19
277 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S19-G3, White Winter 2019 Miembro de Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 583
