Saltar al contenido principal
Shark Rotator Slim-Light Lift-Away Upright Motor Replacement
Qué necesitas
  1. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: paso 1, imagen 1 de 2 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement, Motor: paso 1, imagen 2 de 2
    • Push the red Lift Away button down and lift up on the vacuum handle to detach the base.
    • The handle was removed for convenience but is not required.
  2. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 2, imagen 1 de 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 2, imagen 2 de 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 2, imagen 3 de 3
    • Remove the two 19mm Phillips #2 screws located in the red plastic piece behind the filter.
  3. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 3, imagen 1 de 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 3, imagen 2 de 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 3, imagen 3 de 3
    • Flip over vacuum and remove the six 12.7mm Phillips #2 screws from the base.
    • Take off white plastic cover exposing the motor in its insulation.
  4. Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 4, imagen 1 de 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 4, imagen 2 de 3 Shark Rotator Slim-Light Lift-Away Upright Motor Replacement: paso 4, imagen 3 de 3
    • Remove the motor from the base and slide the insulation down along the wires.
    • Find the plastic caps on top of the black and white wires. Using pliers twist and carefully remove these caps.
    • Needle nosed pliers are recommended but not necessary.
    • These plastic caps are somewhat sensitive and can be difficult to take off. Additionally once taken off they can become unusable.
Conclusión
Una persona más ha completado esta guía.
Joshua Morrison
Miembro Desde 01/24/19
196 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S19-G3, White Winter 2019 Miembro de Cal Poly, Team S19-G3, White Winter 2019
CPSU-WHITE-W19S19G3
5 Miembros
12 Guías creadas
Un comentario
What is the motor PN and where can I get one?
Dennis Meece - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 1,497
