Introducción
The Shark Rotator Powered Lift-Away has two LED headlights to assist in vacuuming in poorly lit areas. The vacuum's headlights are designed to last approximately 7 years. Replacement of the headlights is needed to keep the vacuum at optimal condition. This replacement guide demonstrates how to replace both LED headlights in the vacuum.
Qué necesitas
Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
2 personas más completaron esta guía.
