Saltar al contenido principal
Shark Rotator Powered Lift-Away Speed Headlight Replacement
Qué necesitas
  1. Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: paso 1, imagen 1 de 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement, Headlight: paso 1, imagen 2 de 2
    • Flip the vacuum on its underside, and use a coin to rotate the cam-screws on the bottom panel so that their grooves are parallel with the front of the vacuum.
  2. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 2, imagen 1 de 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 2, imagen 2 de 2
    • Squeeze the sides of the roller brush cover release clasp, and swing the cover open.
  3. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 3, imagen 1 de 1
    • Using a T20 screwdriver remove five 15.9 mm screws on the outside of the cover.
  4. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 4, imagen 1 de 2 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 4, imagen 2 de 2
    • Using a T20 screwdriver, remove three 13.4 mm screws from where the roller brush cover attaches to the bottom of the vacuum.
  5. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 5, imagen 1 de 1
    • Using a T20 screwdriver, remove two 13.4 mm screws from under the wheels.
  6. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 6, imagen 1 de 1
    • Using a T20 screwdriver, remove two 15.9 mm screws behind the vacuum wheels.
  7. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 7, imagen 1 de 1
    • Using a PH0 screwdriver bit, remove the single 13.4 mm screw in between the roller brush and where the release clasp was attached.
  8. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 8, imagen 1 de 1
    • Using a T20 screwdriver, remove the single 13.4 mm screw from behind the belted end of the roller brush.
  9. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 9, imagen 1 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 9, imagen 2 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 9, imagen 3 de 3
    • Flip the vacuum into the upright position, and use a spudger to open the front assembly cover by prying the seam where the colored front assembly and the grey side covers meet.
  10. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 10, imagen 1 de 1
    • Separate the front assembly cover from the vacuum.
  11. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 11, imagen 1 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 11, imagen 2 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 11, imagen 3 de 3
    • Use a spudger to remove the headlight covers by prying the seams where the headlight covers meet the bottom front of the vacuum.
  12. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 12, imagen 1 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 12, imagen 2 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 12, imagen 3 de 3
    • Pull the LED headlight strand up and away from where it is attached to the bottom front of the vacuum.
  13. Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 13, imagen 1 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 13, imagen 2 de 3 Shark Rotator Powered Lift-Away Speed Headlight Replacement: paso 13, imagen 3 de 3
    • Pinch the tabs on the circuit board clasp for the LED headlight inwards , and pull the clasp up and away to detach the headlight.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team S4-G6, White Fall 2018 Miembro de Cal Poly, Team S4-G6, White Fall 2018
CPSU-WHITE-F18S4G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 2,054
