Introducción
When the Shark Rotator Powered Lift-Away is difficult to maneuver or fails to pick up dirt, inspect the roller brush for clogs or damage. Excessive obstructions will cause the vacuum to not operate as intended.
Qué necesitas
Push the lift away button and pull the handle up to separate the body from the wand section.
Remove the 13 screws (circled in yellow) using a phillips screwdriver.
Remove the one screw (circled in red) that has a Torx head (might be Phillips head on some models).
Remove the horizontal screw (circled in orange) that attaches the gray side panel (necessary to remove the white cap on the roller brush in step 8)
Remove white cap with a Flathead screwdriver or any other wedge-like tool.
12 personas más completaron esta guía.
19 comentarios
Same. Need a new brush bar.
I appreciate the info you had posted. It was easy to follow and helped me to save money on buying a new vacuum!
I have the same question. Where can I find the brushbar to the Shark Rotator Professional lift-away mv650?
i’m getting a little frustrated because my carpet’s pile is not getting lifted and cleaned.
Venette
7 August 2019
Does anyone get a reply?
