Saltar al contenido principal
Shark Rotator NV502 Roller Brush Motor Replacement
Qué necesitas
  1. Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush: paso 1, imagen 1 de 2 Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush: paso 1, imagen 2 de 2
    • Pull the handle while pressing the lift away button to remove the body of the vacuum.
  2. Shark Rotator NV502 Roller Brush Motor Replacement: paso 2, imagen 1 de 2 Shark Rotator NV502 Roller Brush Motor Replacement: paso 2, imagen 2 de 2
    • Flip the base of the vacuum over to access the bottom.
    • Remove the two small wheels with a metal spudger.
  3. Shark Rotator NV502 Roller Brush Motor Replacement: paso 3, imagen 1 de 2 Shark Rotator NV502 Roller Brush Motor Replacement: paso 3, imagen 2 de 2
    • Remove the nine 16 mm screws using the Phillips #2 Screwdriver. Press on the side tabs in the middle of the panel and pull up to reveal the screw under the hose connection.
    • Remove the two 13.5 mm screws using the Phillips #2 Screwdriver.
  4. Shark Rotator NV502 Roller Brush Motor Replacement: paso 4, imagen 1 de 2 Shark Rotator NV502 Roller Brush Motor Replacement: paso 4, imagen 2 de 2
    • Pull up on the cover and move it to the side.
    • Remove the wire attached to the base by squeezing the pin and pulling up.
  5. Shark Rotator NV502 Roller Brush Motor Replacement: paso 5, imagen 1 de 2 Shark Rotator NV502 Roller Brush Motor Replacement: paso 5, imagen 2 de 2
    • Remove the two 11 mm screws using the Phillips #2 screwdriver.
    • Lift the roller brush cover up.
  6. Shark Rotator NV502 Roller Brush Motor Replacement: paso 6, imagen 1 de 1
    • Pull out the roller brush.
  7. Shark Rotator NV502 Roller Brush Motor Replacement, Roller Belt: paso 7, imagen 1 de 2 Shark Rotator NV502 Roller Brush Motor Replacement, Roller Belt: paso 7, imagen 2 de 2
    • Remove the roller belt from around the roller brush and the motor gear.
  8. Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush Motor: paso 8, imagen 1 de 2 Shark Rotator NV502 Roller Brush Motor Replacement, Roller Brush Motor: paso 8, imagen 2 de 2
    • Lift the motor out of the base.
    • Disconnect the pins attaching the wires to the motor by pulling on the pins.
Conclusión
3 personas más completaron esta guía.
Caroline Swanson
Miembro Desde 10/05/16
1,372 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-3, Livingston Fall 2016 Miembro de Cal Poly, Team 4-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G3
4 Miembros
19 Guías creadas
6 comentarios
Any idea where to get a replacement control board for a NV501 machine? Brush motor checks out, but no power going to brush motor (though vacuum suction is fine).
Dave H - Contestar
Any idea where to get a replacement control board for the NV501?
Dave H - Contestar
Did you ever find a board, Dave?
Aaron king -
Wife took all apart; quite impressed - but what voltage does beater motor run at? Gotta get a multimeter which are cheap now; Ck red and white leads to cute little motor; and if no power is reaching motor i’ll have the same question as DAVE… and also need to find part (and price of part) if it’s fhe motor …
outdoorjanitorial - Contestar
I’m in the same boat here, Pretty sure my brush motor is going out. It keeps stuttering. I’ve cleaned everything but the filters. If cleaned filters don’t fix the problem, which I don’t know why they would, I need to buy a new brush motor. I don’t want to trash a vacuum only because of a easy to replace motor piece. If anyone finds where to buy it let us know!
FangerZero -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 8,218
