Saltar al contenido principal
Shark Rocket Zero-M Belt Replacement
Qué necesitas
  1. Shark Rocket Zero-M Belt Replacement, Belt: paso 1, imagen 1 de 1
    • Flip the vacuum on its right side.
  2. Shark Rocket Zero-M Belt Replacement: paso 2, imagen 1 de 3 Shark Rocket Zero-M Belt Replacement: paso 2, imagen 2 de 3 Shark Rocket Zero-M Belt Replacement: paso 2, imagen 3 de 3
    • Turn the T10 Security Bit screwdriver counterclockwise to remove the 15mm screw.
  3. Shark Rocket Zero-M Belt Replacement: paso 3, imagen 1 de 3 Shark Rocket Zero-M Belt Replacement: paso 3, imagen 2 de 3 Shark Rocket Zero-M Belt Replacement: paso 3, imagen 3 de 3
    • Turn the vacuum face down.
  4. Shark Rocket Zero-M Belt Replacement: paso 4, imagen 1 de 3 Shark Rocket Zero-M Belt Replacement: paso 4, imagen 2 de 3 Shark Rocket Zero-M Belt Replacement: paso 4, imagen 3 de 3
    • Use a spudger to pry the side of the vacuum open.
  5. Shark Rocket Zero-M Belt Replacement: paso 5, imagen 1 de 3 Shark Rocket Zero-M Belt Replacement: paso 5, imagen 2 de 3 Shark Rocket Zero-M Belt Replacement: paso 5, imagen 3 de 3
    • Use a spudger to pry the old belt away from the two gears.
    • The new belt will be tight and difficult to put back on. In order to reinstall, place the belt on the brushroll, then rotate the brushroll a couple rotations to make sure the belt is aligned correctly.
  6. Shark Rocket Zero-M Belt Replacement: paso 6, imagen 1 de 1
    • Repeat on the other side of the vacuum.
Conclusión
Nadia Martinez
Miembro Desde 04/15/21
133 Reputación
1 Guía escrita
Equipo
Un comentario
What is the belt part number looking but can not fine.
Help would be greatly appreciated thank you
jason kennedy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 51
Todo El Tiempo: 3,347
