Introducción
This is a step by step guide to replacing busted LED lights on the Shark Rocket HV381.
Qué necesitas
On the right-bottom of the body, pull down the black switch. You will hear an audible click when you detach the body from the vacuum head.
On the back of the vacuum head, located near the bottom, should be a row of screws. Using the T15 Screwdriver, remove all the screws on the bottom and the sides.
Casi Terminas!
Conclusión
