Introducción
This guide is to help consumers remove the rotary belt from their Shark rocket HV301. Be sure to have the proper tools and replacement parts available prior to beginning this guide.
Qué necesitas
Flip the vacuum so the bottom base is visible.
Gently pry the bottom two wheels off with a plastic opening tool.
16 personas más completaron esta guía.
4 comentarios
Where can I find the rotary belt for the Shark Duo?
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Thanks for the guide it came in super handy
I just wish there were instructions on how to put the vacuum cleaner back together. I have memory issues and have a hard time going in reverse when I look at the dissembly process.
The Instructions were on the spot and even someone like me was able to disassemble the Shark Rocket.
Now to figure out how to reassemble it.
Thank you,
John
