Saltar al contenido principal
Shark Professional Steam Pocket Mop Water Tank Cap Replacement
  1. Shark Professional Steam Pocket Mop Water Tank Cap Replacement, Water Tank Cap: paso 1, imagen 1 de 2 Shark Professional Steam Pocket Mop Water Tank Cap Replacement, Water Tank Cap: paso 1, imagen 2 de 2
    • Turn off the Steam Pocket Mop and unplug it from the wall.
    • Be sure that the water in the water tank cools to room temperature before proceeding.
  2. Shark Professional Steam Pocket Mop Water Tank Cap Replacement: paso 2, imagen 1 de 3 Shark Professional Steam Pocket Mop Water Tank Cap Replacement: paso 2, imagen 2 de 3 Shark Professional Steam Pocket Mop Water Tank Cap Replacement: paso 2, imagen 3 de 3
    • Remove the water tank cap from the water tank reservoir.
    • Turn the cap towards the upward position.
    • Rotate counter-clockwise until it loosens.
    • When reassembling, align the grooves of new water tank cap with the opening of water tank reservoir and then push in.
Conclusión
2 personas más completaron esta guía.
Tyler Wicke
Miembro Desde 10/17/18
237 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S1-G3, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G3, Rose Fall 2018
UWT-ROSE-F18S1G3
4 Miembros
10 Guías creadas
12 comentarios
Need a water cap for S3901 N3 11 Shark steam mop. They said they discontinued and I have ordered two online and neither will work. And I really going to have to buy a new one?
shannon poole - Contestar
Same here did you come across one
carl yardley -
Did you find any place that sold these caps? I’m in the same boat need a new water cap.
Rick -
hola a mi trapeador shark lift away no le sale vapor y es nuevo tendra algun defecto?
Eveliza Higuera - Contestar
Any updates on getting this part
bryn.rees - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 48
Todo El Tiempo: 9,619
