Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Shark Professional Steam Pocket Mop, utiliza nuestros manuales de servicio .
  1. Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 1, imagen 1 de 2 Shark Professional Steam Pocket Mop Front Panel Disassembly, Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 1, imagen 2 de 2
    • Unwrap the power cord from the handle.
    • Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
    • Pull the handle to separate it from the body.
  2. Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 2, imagen 1 de 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 2, imagen 2 de 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 2, imagen 3 de 3
    • Remove the three 12.0 mm Phillips head #2 screws where the handle connects to the body.
    • Remove the plastic cap.
  3. Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 3, imagen 1 de 2 Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 3, imagen 2 de 2
    • Remove the three 16.0 mm T10 Torx screws near the top of the body and remove the water tank cap.
    • The third screw is directly on other side of the bottom screw in the photo.
  4. Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 4, imagen 1 de 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 4, imagen 2 de 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 4, imagen 3 de 3
    • Remove steam control button cover with a metal spudger.
    • Remove the two 12.0 mm Phillips head #2 screws underneath.
    • Remove the plastic rim with clear plastic cover.
  5. Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 5, imagen 1 de 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 5, imagen 2 de 3 Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 5, imagen 3 de 3
    • Remove the Shark logo decal on the front of body using a metal spudger.
    • Pull out the plastic cover to remove.
  6. Shark Professional Steam Pocket Mop Front Panel Disassembly: paso 6, imagen 1 de 1
    • Pop off the grey front plate to expose the control panel and screws necessary to open mop body.
Brett Wilson
Miembro Desde 02/12/18
992 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S15-G1, Boczar Spring 2018 Miembro de USF Tampa, Team S15-G1, Boczar Spring 2018
USFT-BOCZAR-S18S15G1
4 Miembros
14 Guías creadas
Un comentario
Here is a video to help with dismantling if you'd like to see the possible original guide first posted on YouTube by George Robles September 16, 2015 years before.
https://youtu.be/18mMbbMjqzs
No one knew or posted before me because I looked everywhere and why I created the video.
But I am curious where you got your information from if it was not my video.
George Robles - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 61
Todo El Tiempo: 4,107
