Introducción
To access the innermost components including the electronic valve and heating element, opening the mop body is required. Before doing any disassembly on your Shark Professional Steam Pocket Mop, make sure to unplug the mop and empty the water tank for your safety.
Herramientas
Partes
No se especificaron partes.
Unwrap the power cord from the handle.
Remove the 56.0 mm Phillips head #2 screw located above the water tank cap.
Pull the handle to separate it from the body.
Remove the three 12.0 mm Philips head #2 screws connected to the dark grey plastic trim.
2 personas más completaron esta guía.
