Saltar al contenido principal
Shark Pet Perfect II Front Belt Replacement
Qué necesitas
  1. Shark Pet Perfect II Front Belt Replacement, Front Belt: paso 1, imagen 1 de 1
    • Remove the motorized brush from the dust cup by pulling it apart.
  2. Shark Pet Perfect II Front Belt Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
  3. Shark Pet Perfect II Front Belt Replacement: paso 3, imagen 1 de 2 Shark Pet Perfect II Front Belt Replacement: paso 3, imagen 2 de 2
    • Separate the motorized brush face plate by using a flat prying tool.
  4. Shark Pet Perfect II Front Belt Replacement: paso 4, imagen 1 de 3 Shark Pet Perfect II Front Belt Replacement: paso 4, imagen 2 de 3 Shark Pet Perfect II Front Belt Replacement: paso 4, imagen 3 de 3
    • Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
    • Be careful in handling the belt. If stretched or damaged, the belt can cause the motorized brush to operate incorrectly.
Conclusión
Documentos Adjuntos
Tanner Brown
Miembro Desde 06/27/17
459 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S1-G5, Liner Summer 2017 Miembro de UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
4 Miembros
8 Guías creadas
Un comentario
Thank you for this! I needed the picture to put it back together after I cleaned it out because it was not spinning. Working perfectly now! I also have an extra new battery if anyone needs it. :)
Aaron Woods - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 775
