Saltar al contenido principal
Shark Pet Perfect II Battery Replacement
Qué necesitas
  1. Shark Pet Perfect II Battery Replacement, Battery: paso 1, imagen 1 de 3 Shark Pet Perfect II Battery Replacement, Battery: paso 1, imagen 2 de 3 Shark Pet Perfect II Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate and remove the 7.5mm Philips screw holding the battery cover in place on bottom of the vacuum.
  2. Shark Pet Perfect II Battery Replacement: paso 2, imagen 1 de 3 Shark Pet Perfect II Battery Replacement: paso 2, imagen 2 de 3 Shark Pet Perfect II Battery Replacement: paso 2, imagen 3 de 3
    • Once the cover is removed, slide the plastic retaining bracket down and pull out to remove.
  3. Shark Pet Perfect II Battery Replacement: paso 3, imagen 1 de 3 Shark Pet Perfect II Battery Replacement: paso 3, imagen 2 de 3 Shark Pet Perfect II Battery Replacement: paso 3, imagen 3 de 3
    • Pull the battery out of the compartment.
    • Carefully disconnect the quick disconnect couplers.
    • The Couplers may be tightly secured so it may be necessary to use a small flat device to carefully loosen the coupler.
    • Be sure to use an ESD safe tool like the nylon spudger when working with wires and batteries—this will prevent injury and/or device damage.
  4. Shark Pet Perfect II Battery Replacement: paso 4, imagen 1 de 1
    • Completely remove the old battery from the vacuum .
Conclusión
4 personas más completaron esta guía.
Documentos Adjuntos
Equipo
UW Tacoma, Team S1-G5, Liner Summer 2017 Miembro de UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
4 Miembros
8 Guías creadas
12 comentarios
Removed the single screw but cover will not come off. What do you do?
Adalyn Etelamaki - Contestar
Just tried it. The cover is a bit hard. Gold the vacuum at an angle and slightly push the notch on the cover with a flat screwdriver, it should come out.
PradSim Promo Ads - Contestar
Will it run on cord only
ligthelf - Contestar
NO. Requires batteries.
Jim DeCamp -
1.) Mine was much harder to disassemble, took considerable force.
2.) No one sells form, fit and function replacement batteries, including Shark
3.) The available replacement are much smaller in volume, and hence power, and require padding or they will rattle.
Jim DeCamp - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 30
Ultimos 30 días: 145
Todo El Tiempo: 17,007
