Saltar al contenido principal
Shark Navigator Motor Replacement
Qué necesitas
  1. Shark Navigator Motor Replacement, Roller Brush Compartment: paso 1, imagen 1 de 1
    • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
  2. Shark Navigator Motor Replacement: paso 2, imagen 1 de 2 Shark Navigator Motor Replacement: paso 2, imagen 2 de 2
    • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
    • The screws have varying lengths, so keep track of where each one goes for reassembly.
  3. Shark Navigator Motor Replacement: paso 3, imagen 1 de 1
    • Remove the white plastic cover to expose the roller compartment underneath.
  4. Shark Navigator Motor Replacement, Motor: paso 4, imagen 1 de 1
    • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
    • Make sure to untangle or unhook any wires that are connected to the motor.
    • Once this is done, you can replace the old motor with a new one.
Conclusión
Molina Oung
Miembro Desde 03/27/15
277 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 5-4, Kish Spring 2015 Miembro de UMass Dartmouth, Team 5-4, Kish Spring 2015
UMASSD-KISH-S15S5G4
Miembros de 4
16 Guías creadas
6 Guide Comments
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - Contestar
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - Contestar
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans -
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger -
Have no suction but the roller still spins can it still be the Motor ?
Thompson Mick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 38
Ultimos 30 días: 133
Todo El Tiempo: 16,431
