Saltar al contenido principal
Shark Navigator Lightweight Upright Motor Replacement
Qué necesitas
  1. Shark Navigator Lightweight Upright Motor Replacement, Head Shell: paso 1, imagen 1 de 2 Shark Navigator Lightweight Upright Motor Replacement, Head Shell: paso 1, imagen 2 de 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motor Replacement: paso 2, imagen 1 de 2 Shark Navigator Lightweight Upright Motor Replacement: paso 2, imagen 2 de 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motor Replacement: paso 3, imagen 1 de 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motor Replacement: paso 4, imagen 1 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 4, imagen 2 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 4, imagen 3 de 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motor Replacement: paso 5, imagen 1 de 2 Shark Navigator Lightweight Upright Motor Replacement: paso 5, imagen 2 de 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motor Replacement: paso 6, imagen 1 de 2 Shark Navigator Lightweight Upright Motor Replacement: paso 6, imagen 2 de 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motor Replacement: paso 7, imagen 1 de 2 Shark Navigator Lightweight Upright Motor Replacement: paso 7, imagen 2 de 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motor Replacement: paso 8, imagen 1 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 8, imagen 2 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 8, imagen 3 de 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motor Replacement, Motor: paso 9, imagen 1 de 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motor Replacement: paso 10, imagen 1 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 10, imagen 2 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 10, imagen 3 de 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motor Replacement: paso 11, imagen 1 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 11, imagen 2 de 3 Shark Navigator Lightweight Upright Motor Replacement: paso 11, imagen 3 de 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motor Replacement: paso 12, imagen 1 de 2 Shark Navigator Lightweight Upright Motor Replacement: paso 12, imagen 2 de 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
Conclusión
4 personas más completaron esta guía.
Suzie
Miembro Desde 10/02/17
527 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G6, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Miembros
12 Guías creadas
2 comentarios
Where does one buy the replacement motor?
Michael De La Rosa - Contestar
Where can I get spares??
ck
Clive Kingscote - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 51
Todo El Tiempo: 9,598
