Saltar al contenido principal
Shark Navigator Lightweight Upright Motherboard Replacement
Qué necesitas
  1. Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: paso 1, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: paso 1, imagen 2 de 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motherboard Replacement: paso 2, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 2, imagen 2 de 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motherboard Replacement: paso 3, imagen 1 de 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motherboard Replacement: paso 4, imagen 1 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 4, imagen 2 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motherboard Replacement: paso 5, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motherboard Replacement: paso 6, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motherboard Replacement: paso 7, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motherboard Replacement: paso 8, imagen 1 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 8, imagen 2 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motherboard Replacement, Motor: paso 9, imagen 1 de 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motherboard Replacement: paso 10, imagen 1 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 10, imagen 2 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motherboard Replacement: paso 11, imagen 1 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 11, imagen 2 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 11, imagen 3 de 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motherboard Replacement: paso 12, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
  13. Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: paso 13, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: paso 13, imagen 2 de 2
    • Remove the two 12mm screws using a JIS 1 screwdriver.
  14. Shark Navigator Lightweight Upright Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the wire housing by removing one 12mm screw using a JIS 1 screwdriver.
  15. Shark Navigator Lightweight Upright Motherboard Replacement: paso 15, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 15, imagen 2 de 2
    • Lift up the wire housing from the plastic base using tweezers.
  16. Shark Navigator Lightweight Upright Motherboard Replacement: paso 16, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 16, imagen 2 de 2
    • Free the black and white cables that were previously attached to the motor from their slot.
  17. Shark Navigator Lightweight Upright Motherboard Replacement: paso 17, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 17, imagen 2 de 2
    • Free the motherboard and its connecting parts from the rest of the vacuum.
    • Turn the motherboard upside-down and spread wires out.
  18. Shark Navigator Lightweight Upright Motherboard Replacement: paso 18, imagen 1 de 2 Shark Navigator Lightweight Upright Motherboard Replacement: paso 18, imagen 2 de 2
    • Heat the wire connection's solder joint until the joint looks wet and liquidy.
    • While maintaining contact with the solder iron, free the wire end by pulling the wire away from the board with the tweezers.
    • For instructions on how to solder properly please refer to this soldering technique guide. Cómo soldar y desoldar conexiones
    • Remember which cables were soldered onto where. You will have to re-solder the cables back onto the same joint.
    • Solder iron is extremely hot and should be handled with care. Always wear eye protection when soldering.
  19. Shark Navigator Lightweight Upright Motherboard Replacement: paso 19, imagen 1 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 19, imagen 2 de 3 Shark Navigator Lightweight Upright Motherboard Replacement: paso 19, imagen 3 de 3
    • Completely free the cable by pulling it out of the board.
    • Repeat for the remaining cables. There are 4 total.
Conclusión
Suzie
Miembro Desde 10/02/17
527 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G6, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,553
