Saltar al contenido principal
Shark Navigator Lightweight Upright Hose Replacement
  1. Shark Navigator Lightweight Upright Hose Replacement, Hose: paso 1, imagen 1 de 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: paso 1, imagen 2 de 3 Shark Navigator Lightweight Upright Hose Replacement, Hose: paso 1, imagen 3 de 3
    • Locate the upper connection of the hose found directly below the base of the handle. Push in the the tab on the outside of the tube with your thumb.
    • Pull down on the tube while maintaining pressure on the tab.
    • Separate the upper connection of the tube from the housing, releasing the hose.
  2. Shark Navigator Lightweight Upright Hose Replacement: paso 2, imagen 1 de 2 Shark Navigator Lightweight Upright Hose Replacement: paso 2, imagen 2 de 2
    • Locate the lower attachment of the hose found in the bottom left corner.
    • Pull the hose down towards the floor, releasing the hose from the hose guide.
  3. Shark Navigator Lightweight Upright Hose Replacement: paso 3, imagen 1 de 3 Shark Navigator Lightweight Upright Hose Replacement: paso 3, imagen 2 de 3 Shark Navigator Lightweight Upright Hose Replacement: paso 3, imagen 3 de 3
    • Pull up on the hose pipe located on the right side of the vacuum firmly.
    • Lift the hose pipe upwards and all the way through the plastic guide ring.
Conclusión
Una persona más ha completado esta guía.
Kahye Yu
Miembro Desde 10/02/17
446 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S4-G6, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Miembros
12 Guías creadas
3 comentarios
Where can I find a replacement hose?
Vance Payne - Contestar
How to replace the bottom pick up hose.
rgg20319 - Contestar
How to fix the bottom hose?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 68
Todo El Tiempo: 3,440
