Saltar al contenido principal
Shark Navigator Lightweight Upright Head Shell Replacement
Qué necesitas
  1. Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: paso 1, imagen 1 de 2 Shark Navigator Lightweight Upright Head Shell Replacement, Head Shell: paso 1, imagen 2 de 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Head Shell Replacement: paso 2, imagen 1 de 2 Shark Navigator Lightweight Upright Head Shell Replacement: paso 2, imagen 2 de 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Head Shell Replacement: paso 3, imagen 1 de 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Head Shell Replacement: paso 4, imagen 1 de 3 Shark Navigator Lightweight Upright Head Shell Replacement: paso 4, imagen 2 de 3 Shark Navigator Lightweight Upright Head Shell Replacement: paso 4, imagen 3 de 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Head Shell Replacement: paso 5, imagen 1 de 2 Shark Navigator Lightweight Upright Head Shell Replacement: paso 5, imagen 2 de 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Head Shell Replacement: paso 6, imagen 1 de 2 Shark Navigator Lightweight Upright Head Shell Replacement: paso 6, imagen 2 de 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Head Shell Replacement: paso 7, imagen 1 de 2 Shark Navigator Lightweight Upright Head Shell Replacement: paso 7, imagen 2 de 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Head Shell Replacement: paso 8, imagen 1 de 3 Shark Navigator Lightweight Upright Head Shell Replacement: paso 8, imagen 2 de 3 Shark Navigator Lightweight Upright Head Shell Replacement: paso 8, imagen 3 de 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
Conclusión
Suzie
Miembro Desde 10/02/17
527 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S4-G6, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Miembros
12 Guías creadas
Un comentario
I have been doing exactly what the steps require but have not been able to remove the cover. Each time I am able to release one side the other side snaps back and the fixit tools fall out or fall inside.
Please give me any suggestions to accomplish removing the cover. Thank you.
Diane Snelling - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 978
