Saltar al contenido principal
Shark Navigator Lightweight Upright Dust Cup Replacement
  1. Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: paso 1, imagen 1 de 2 Shark Navigator Lightweight Upright Dust Cup Replacement, Dust Cup: paso 1, imagen 2 de 2
    • Press down on the black, rubber ballish button located on the top of the vacuum.
    • Pull back simultaneous on the plastic handle and remove the dust container.
  2. Shark Navigator Lightweight Upright Dust Cup Replacement: paso 2, imagen 1 de 3 Shark Navigator Lightweight Upright Dust Cup Replacement: paso 2, imagen 2 de 3 Shark Navigator Lightweight Upright Dust Cup Replacement: paso 2, imagen 3 de 3
    • Press the plastic tab in, located on the front of the dust container.
    • Pull up simultaneously on the plastic handle.
  3. Shark Navigator Lightweight Upright Dust Cup Replacement: paso 3, imagen 1 de 2 Shark Navigator Lightweight Upright Dust Cup Replacement: paso 3, imagen 2 de 2
    • Remove the dust cup from the inside of the dust container.
  4. Shark Navigator Lightweight Upright Dust Cup Replacement: paso 4, imagen 1 de 3 Shark Navigator Lightweight Upright Dust Cup Replacement: paso 4, imagen 2 de 3 Shark Navigator Lightweight Upright Dust Cup Replacement: paso 4, imagen 3 de 3
    • Push in the red tab located on the side of the dust cup.
    • Open the dust cup simultaneously with the cone-half pointing downwards.
    • Separate the two halves.
Conclusión
Kahye Yu
Miembro Desde 10/02/17
446 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S4-G6, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 81
Todo El Tiempo: 3,433
