Introducción
Brush heads are prone to collecting debris and unwanted material. This guide will show you how to properly access and remove the brush head.
Qué necesitas
Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
5 personas más completaron esta guía.
2 comentarios
Taking the thing apart is one thing, but identifying the part numbers (motor, belt, brush) to replace the old worn stuff is another. I haven't found the part numbers for these things (or the exploded parts view for the vacuum itself or either of the two power heads. Does anyone know whereabouts these things can be found?
