Introducción
The roller brush and motor need to be removed in order to replce the motherboard. Soldering would be needed for reassembly.
Qué necesitas
Lay the vacuum down by hand and locate the roller brush underneath the vacuum cleaner.
Remove the roller brush from the plastic frame using your hands by lifting it away.
Lift the roller brush motor up and away from its half-cylindrical holder with your hand.
Locate the two wires that were connected to the roller brush motor.
Remove the white wire from the pass-through hole in the divider of the motorized floor brush compartment.
3 personas más completaron esta guía.
