Saltar al contenido principal
Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement
  1. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: paso 1, imagen 1 de 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: paso 1, imagen 2 de 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement, HEPA Filter: paso 1, imagen 3 de 3
    • Press the latch below the HEPA filter on the bottom of the front body of the vacuum and pull outwards with your hands.
    • Pull the grey and blue plastic cover down and away with your hands.
  2. Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: paso 2, imagen 1 de 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: paso 2, imagen 2 de 3 Shark Navigator Lift-Away Deluxe NV360 HEPA Filter Replacement: paso 2, imagen 3 de 3
    • Pull the HEPA filter out by the grey plastic tab in the middle of the grate with your hands.
    • Wiggle it around as you are pulling if the HEPA filter is not coming out easily.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S15-G2, Livingston Fall 2017 Miembro de Cal Poly, Team S15-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G2
3 Miembros
14 Guías creadas
Un comentario
I bought two different HEPA filters for the front, and they just blow off. What is the part with the tab that you push down to get the filter out? Is that an extra part cuz I don't even have that.
Kelly Kusemamuriwo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 30
Ultimos 30 días: 82
Todo El Tiempo: 6,346
