Saltar al contenido principal
Shark Navigator Freestyle SV1106 Roller Brush Replacement
Qué necesitas
  1. Shark Navigator Freestyle SV1106 Roller Brush Replacement, Roller Brush: paso 1, imagen 1 de 2 Shark Navigator Freestyle SV1106 Roller Brush Replacement, Roller Brush: paso 1, imagen 2 de 2
    • Remove the black rubber band from the roller brush
    • In most models there will be a plastic cover over the rubber band. You will use the quarter to twist the latch and take off the cover
  2. Shark Navigator Freestyle SV1106 Roller Brush Replacement: paso 2, imagen 1 de 3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: paso 2, imagen 2 de 3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: paso 2, imagen 3 de 3
    • Use the bristles to pull the end of the brush that was connected to the belt away from the vacuum.
  3. Shark Navigator Freestyle SV1106 Roller Brush Replacement: paso 3, imagen 1 de 3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: paso 3, imagen 2 de 3 Shark Navigator Freestyle SV1106 Roller Brush Replacement: paso 3, imagen 3 de 3
    • Slide the roller belt off of the roller brush and pull the roller away from the motorized brush.
Conclusión
3 personas más completaron esta guía.
Zachary Liu
Miembro Desde 01/24/18
604 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S1-G5, Livingston Winter 2018 Miembro de Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
3 Miembros
10 Guías creadas
3 comentarios
but where can I buy the brush for model SV1106?
ellenmccarthycalif - Contestar
Replace the brush? They are not available for purchase.
Ken Codeglia - Contestar
If only you could buy a brush besides second hand on eBay…
isaac.a.brown - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 2,957
