Saltar al contenido principal
Shark NV352 Roller Brush Replacement
Qué necesitas
  1. Shark NV352 Roller Brush Replacement, Roller Brush: paso 1, imagen 1 de 2 Shark NV352 Roller Brush Replacement, Roller Brush: paso 1, imagen 2 de 2
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Roller Brush Replacement: paso 2, imagen 1 de 1
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Roller Brush Replacement: paso 3, imagen 1 de 2 Shark NV352 Roller Brush Replacement: paso 3, imagen 2 de 2
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Roller Brush Replacement: paso 4, imagen 1 de 2 Shark NV352 Roller Brush Replacement: paso 4, imagen 2 de 2
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Roller Brush Replacement: paso 5, imagen 1 de 2 Shark NV352 Roller Brush Replacement: paso 5, imagen 2 de 2
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Roller Brush Replacement: paso 6, imagen 1 de 2 Shark NV352 Roller Brush Replacement: paso 6, imagen 2 de 2
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Replacement: paso 7, imagen 1 de 1
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Replacement: paso 8, imagen 1 de 1
    • Take out the roller brush by lifting it out of its tray.
Conclusión
8 personas más completaron esta guía.
Amy Moran
Miembro Desde 09/22/17
588 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S18-G5, Forte Fall 2017 Miembro de Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 75
Todo El Tiempo: 4,618
